OpenSCADAWiki: Home Page En/Doc/SSL ...
This is an old revision of HomePageEn/Doc/SSL from 2009-05-21 13:38:56..
Module <SSL> of subsystem “Transports”
Russian (1 Kb) Ðóññêàÿ âåðñèÿ
Ukrainian (1 Kb) Óêðà¿íñüêà âåðñ³ÿ
Module: SSL
Type: Òðàíñïîðò
Source: tr_SSL.so
Version: 0.8.0
Author: Roman Savochenko
Translated:Maxim Lysenko
Description: Provides transport based on the secure sockets' layer. OpenSSL is used and SSLv2, SSLv3 and TLSv1 are supported.
License:GPL
Introduction
The module SSL of the transport provides the support of transport based on secure sockets layer (SSL) into the system. In the basis of the module there is the library OpenSSL. Incoming and outgoing transports of protocols SSLv2, SSLv3 and TLSv1 are supported.
It is possible to add new incoming and outgoing transports through the transport subsystem configuration in any configurator of OpenSCADA system.
1. Incoming transports
The configured and runnig incoming transport opens server SSL-socket for the expectation of connection of the clients. SSL-socket is a multi-stream, ie when the client connects, the client SSL-connection and a new stream in which the client is served are created. Server SSL-socket in this moment switches to the waiting for the request from the new client. Thus the parallel service of the clients is achieved.
Each incoming transport is necessarily associated with one of the available transport protocols, to which incoming messages are transmitted. In conjunction with the transport protocol is supported by a mechanism of the combining of pieces of requests, disparate while transferring.
Configuration dialog of the incoming SSL-transport is depicted in Figure 1.
Configuration dialog of the incoming SSL-transport. (104 Kb)
Fig.1. Configuration dialog of the incoming SSL-transport.
2. Outgoing transports
Configured and running outgoing transport opens the SSL connection to the specified server. In the case of destroying of the connection, outgoing transport is disconnected. In order to resume the connection transport must be re-run.
Main tab of the configuration page of outgoing SSL-transport is shown in Fig.2.
Main tab of the configuration page of the outgoing SSL-transport. (83 Kb)
Fig.2. Main tab of the configuration page of the outgoing SSL-transport.
3. Certificates and keys
For a valid module work certificates and private keys are required. In the case of the incoming SSL-transport (the server) they are compulsory. In the case of outgoing SSL-transport they can not be even installed though their using is desirable.
The simplest configuration of the certificate is self-subscription certificate and private key. The following describes how to create them using the tool openssl:
# Generation the secret key
$ openssl genrsa -out ./key.pem -des3 -rand /var/log/messages 2048
# Generation of self-subscription certificate
$ openssl req -x509 -new -key ./key.pem -out ./selfcert.pem -days 365
Next, the contents of the files key.pem and selfcert.pem is copied into the text field of the certificate and key. Password of the private key is installed in the appropriate field.
Links
HomePageEn/Function
HomePageEn/Using/PLC/firmware
HomePageEn/Using/SmartHouse
