OpenSCADAWiki: Home Page En/Doc/ Comedi ...
The module <Comedi> of subsystem "Data Acquisition"
Module: Comedi
Name: DAQ boards by Comedi
Type: DAQ
Source: daq_Comedi.so
Version: 1.0
Author: Roman Savochenko
Description: ISA, PCI, PCMCIA, USB DAQ boards collection by Comedi (http://www.comedi.org).
License: GPL
Introduction
The module provides the OpenSCADA system with the support data sources of realtime, which based on data acquisition boards (DAQ) from different manufacturers, installed on the buses: ISA, PCI, PCMCIA and USB. Drivers implementation for all supported variety boards on Linux kernel side, and also application level library, provided by project Comedi. Full supported boards list, modules to Linux kernel, by project Comedi, also and the module you can get by link: http://comedi.org/hardware.html.
Into Comedi project the unified interface implemented for access to boards data on types data level, that allows, made doing with typical data the boards, not to care further about new hardware supporting on the module side. In current version of the module implemented support for data types: AI (simple poll mode without FIFO), AO, DI, DO, DIO.
The module implements the functions of the horizontal reservation, namely, working in conjunction with the remote station of the same level.
1. Controller object
DAQ—boards by library Comedi into OpenSCADA configured with new controller object creation (Fig.1), the container parameters' objects — DAQ boards.
Configuration tab of the controller object. (100 Êá)
Fig.1. Configuration tab of the controller object.
From this tab you can set:
It should be noted that the acquisition data is mainly done in synchronous mode, but for some modules of analog inputs (AI-ADC) that would be optimal asynchronous mode, due to the length of time for value setting after switching a multiplexor channel. For board Advantech PCL-813B the time is 5ms.
2. The controller's parameter object
The parameter object is a direct representative-reflection for DAQ-board, which contained attributes set with types and it quantity depending from specific board. Parameter's object configuration tab is shown in Figure 2.
Parameter's object configuration tab — DAQ board. (75 Êá)
Fig.2. Parameter's object configuration tab — DAQ board.
With the parameter's object configuration tab you can set:
Tab "Attributes" for board ACL-8113 is shown in Figure 3. For some types of data can be accessed "Configuration" tab. For example, this tab (Fig.4) for boards with analog inputs has the values set timeout and ranges selection for each channel.
Tab "Attributes" of parameter object of board ACL-8113. (85 Êá)
Fig.3. Tab "Attributes" of parameter object of board ACL-8113.
Tab "Configuration" of parameter object of board ACL-8113. (88 Êá)
Fig.4. Tab "Configuration" of parameter object of board ACL-8113.
3. Notes
To build and work of the module only needs library comedilib which is present in most distributions repositories. However, the drivers modules need build separately, and its archive you can download here: http://comedi.org/download.html.
The module work is tested on the following boards:
Links
HomePageEn/Function
There are 4 files on this page.[Display files/form]
Comments [Hide comments/form]
