6.2 Visualization interface projects
Objectives of this stage are:
-  Projects of the visualization interfaces implementations at level of the VCA data model in the UI.VCAEngine module:
-  Link tools development of the frame: local links inside the frames, external links to parameters of the data acquisition subsystem of OpenSCADA and actions of the interface to events.
-  Pages' tree of the project and their relations development.
-  Projects of the visualization interfaces implementation in the presentation(visualization) module UI.Vision(Qt):
-  Navigator on the projects forming.
-  Configuration dialog of a project's page forming;
-  Implementing of support for possibility of direct graphical forming of a page on the project's level with possibility of the visual linkage (including the logic links).
At this stage, it was added the mechanism of VCA projects formation by means of the building of the visualization pages in hierarchical form, which corresponds to logical links in the final VCA interface. During the implementation of this stage, the work was begun on adaptation of the visualization module "Vision" to use the control interface of OpenSCADA instead of direct-strong links. These works have led to significant unification of the various dialogues, control structures and user interface in general.
At this stage implemented:
-  Links mechanism. Just on the parameters of data sources! Internal links will be implemented in subsequent stages.
-  Inspector of links of the module "Vision", using scenarios of the control interface of OpenSCADA.
-  Mechanism of formation of the pages' tree based on the terms: page-template and page-container. This mechanism allow you to simply describe the relationship between the pages of most known types of user interface with an effective addressing and links to pages either individually or by template.
-  Navigator through the project's tree, as on the scripting language of control interface and in the module "Vision", using the same scenarios of the control interface.
-  Dialogue of the project's and the project page's configuration. In fact, the configuration dialogs of the project's and the library's elements are combined and also transfer to weak links of the control interface of OpenSCADA is done.
-  Thanks to the unification of the interface of access to the elements of the library and the project, possibility of direct formation of pages on project's level is implemented.
